Request for Jeeps with Air Suspension (Quadralift)
Posted: Fri Jan 25, 2013 5:34 pm
On Jeep Grand Cherokee Model Years 2011-Current there is an optional feature (standard on Overland, Overland Summit) to have their Quadralift Air Suspension. In a nut shell, it allows the Jeep to change its ride height over a 4" span.
One of the major complaints from those that are lucky enough to have it is that you cannot lock the ride height (I think Land Rovers can). The current restrictions are that you must maintain a certain speed in order to keep the ride height. Once you go over that speed the height changes.
Here is a quick break down of the limitations:
You cannot go over 25 MPH in Off-Road II (2.6" higher than normal ride height)
You cannot go over 39 MPH in Off-Road I (1.3" higher than normal ride height)
Must be doing 62 - 66 MPH for greater than 20 seconds to drop into Aero (0.5" below normal ride height) OR go into "Sport Mode"
You cannot go over 25 MPH in Park Mode (1.5" below normal ride height)
SRC: http://www.wk2jeeps.com/wk2_quadralift.htm
This gets really annoying, especially when trying to remember what happens at what speed.
So, for my request, is it possible to have your guys work on something that allows us to either modify the speeds when these changes occur or lock a height in (like a lift kit)?
Your tuner is getting a lot of attention from the WK2 Jeep Grand Cherokee owners now that there are tunes available. I think this would make your product an even bigger win with owners!
If you need more detail, or would like people to chime in here to back this request, let me know.
