problem with 2012 wrangler released tunes
bin_hamdan
hi
kindly be informed that i have 2012 sport wrangler manual export model and facing a problem after installing the tune
no throttle response at all and RPM 500 Idle
find the link below for more info
http://www.diablosport.com/forum/viewto ... 2&start=30
i guess mike resolved it for one of the members
i will be waiting for assistance from you DS team to resolve this issue at the earliest
regards
regards
Re: problem with 2012 wrangler released tunes
please post a copy of the backup file from your tool and I will make a new tune for you, and it will also be fixed in an update soon.
bin_hamdan
kindly find the attached original backup
- PCM_68090880AG.drg
- original backup
- (91.17 KiB) Downloaded 166 times
here is a new tune for youbin_hamdan wrote:kindly find the attached original backup
- pcm_68090880ag_001.drg
- (72.71 KiB) Downloaded 167 times
What is in this tune that differs from the 1st release??
2012 JKU RUBIKONG: Far too much to list here...
its corrected for use with a manual trans.
bin_hamdan
thank you mikemikel wrote:here is a new tune for youbin_hamdan wrote:kindly find the attached original backup
diffrence is noticeable
Mikel-
I called in to tech support earlier...
My tuner locked me out of performance mode but was in perf93oct + quick tune. Mike (tech) walked me thru a reset and it save my "stock" tune to my t1000 (so I thought). After the reset I went to reload the perf93oct and it is now a DOG! I tried reloading the stock tune and believe my stock tune was overwritten by the perf93oct when it was loaded back into the ecu as the stock tune. Is there a crom from my now corrupted t1000 that I can download?
2012 JKU Rubicon automatic
Thanks!
Mike
Thanks!
Mike
the tool will not save a tune as a backup, can you export a copy of the backup and last tune written and email them to me?
Yes.
Give me a minute...
Would it be best if I called the tech line and asked for you? I have to get this running right. Before the "restore" it was running fantastic I just need to adjust the idle level a little and couldn't get in as it said it was married to an unknown tool. Now it runs worse than stock and Ive tried reloading stock back and forth a couple of time w/o any change...
I have your email from yesterday and will send it right away unless I should call too??
I only have mikem's email...
Give me a minute...
Back up and perf93oct tunes emailed to Mike L...
replied, lets do a cal update tomorrow and get it all back to stock.
limp it for 200 mile drive back and forth for work tomorrow??
its not OK after you restore the backup?RuffRider wrote:limp it for 200 mile drive back and forth for work tomorrow??
plug it into the vehicle, go to setting/advanced/force cal update, and post the Key here, and I will give you the password to proceed.
Tahnks
Tahnks
