Hey guys, I figured I start my own thread instead of keep thread jacking lol.
I am still having idle issue at least once a day. Usually when the fan kick on my car would shake and the rpm drop down like it's going to stall out then it catches and go back to normal idle. Doesn't happen all the time but like I said it happens at least once a day.
It also does the same sometimes while very slowly coming to a stop or while just sitting and idling.
I checked for leaks and I don't have any. I also tried to raise the rpm to 700(50rpm) but this caused my idle to bounce up and down constantly which at the same time I can hear the engine revving up and down.
Not sure why this is happening other than to suspect the tune. Never had this problem before until the first day I loaded the tune.
2013 mustang gt MT82 Idle problem
- 5liter Monsta
----2013 Mustang GT MT82 DIBM 401a Premium Pack----
Re: 2013 mustang gt MT82 Idle problem
can you post the Last tune written?
Also, can you change the idle, then load the last tune written again, so we can see whats happening there?
Also, are you using the update that was released yesterday?
- 5liter Monsta
Not sure mike. I haven't updated since few weeks ago but the firmware I'm on are,
Ford tune 1t01ja
Ford pid 1r01a
Application 1r03a
Ford tune 1t01ja
Ford pid 1r01a
Application 1r03a
thats pretty old, there have been quite a few updates since then, connect it to a PC, let the updater run, then clcik update/check now so it will replace the test files.
- 5liter Monsta
So should I reload the tune after update?
That version was actually given to us only about 2 weeks ago from Brian.
right, but the intune itself is 5 versions behind, we're on 1r03f currently
the custom tunes dont need to be reloaded.
- 5liter Monsta
Wow, didn't realize I was that far back Lol.
I'm not on custom tune so I should reload? I'm on 91 air aid tune.
yes, reload it once the update is done, and let us know.
- 5liter Monsta
K. Thanks mike.
