Trinity will not connect to Pickup
cdsflyboy
Post by cdsflyboy »
i have a 2010 dodge ram 1500
I have the T1000 tuner
I plug my cord into the OBD2 port then my tuner and it doesnt even power on. But when i plug it into my computer it powers on fine.
Do i have to have the micro USB plugged in at the same time as when it plugged into the OBD2 port?
Re: Trinity will not connect to Pickup
no, it should power up on its own.
can you try it in another vehicle?
cdsflyboy
Post by cdsflyboy »
It starts up just fine in another vehicle.
Is there a fuse or something that would not send power to it if it were to be burnt?
yeah.. check your cig lighter and aux power fuses... those also supply power to the obd port, so if a fuse is blown, you have no power to your obd port, which would explain why it's not powering up for you in your vehicle..
cdsflyboy
Post by cdsflyboy »
Well I replaced a fuse for my window switch because my windows were not going up or down...but my tuner powers on now....I'm not sure if those are on the same circuit
Return to “General Support”
