180 T-Stat and Trinity G version review
Posted: Sun Feb 10, 2013 4:57 pm
First I want to say I know I had been a little negative about the trinity during all it's hiccups. I stopped downloading them a while ago. Well today after seeing and reading that all the major issues are history now. I downloaded the G version. It was a very very very easy download and very easy to install . After install the car ran with no problem.. I was able to adjust the G version tune with no problem whats so ever.
I installed the 93 Oct Tune, adjusted the throttle boost to 20% , Raised Shifts pts, raised Rev level, and being that I installed a 180- T-Stat today as well. I adjusted / lowered ALL fan settings 20 degrees.. Fan goes on anywhere between 178 -188 degrees depending on driving conditions compare to 198-208. I drove around today for about 2.5 hrs.. This car is a BEAST.. You really feel the difference at WOT.
Today its a BEAUTIFUL 71 degrees here in North Fl.
Prior to installing 180-Tstat engine temps was running between 195 to 215 depending on driving conditions. After installing 180-Tstat and adjusting fans here's how my engine was running today ..
Idle and stop and go traffic 185-187 degrees
Cruising 70 mph 182-185 degrees
Driving at 90-100 mph 188-190 degrees
Driving at 120 mph 195-200 degrees
Fans kicked on at the actual temps I set.. Have to get use to the fans being on most of the time.. However that is a small price to pay for a cooler engine.
