Disable DoD
dbroylz
Disable DoD
Post by dbroylz »
I have a 12 silverado with the 5.3. I'm running the diablo tune and the DoD won't turn off. I've seen that you can do a custom tune to fix it. Would you do that for me?
ECM_12640857_LastTuneWritten.grg
(64.89 KiB) Downloaded 158 times
ECM_12640857_Backup.grg
(65.24 KiB) Downloaded 150 times
Re: Disable DoD
an intune update was put out days ago that addresses/fixes this issue... connect your intune to your windows pc and let it auto-update... then reinstall the tune, modify it to disable DOD, and you'll be good to go..
TJEli
Re: Disable DoD
Post by TJEli »
Is it in the auto-updater yet? If not, here is the file. Drag it to your intune drive and let the tool update.
-Eli
InTune-1t03gc.itf
(1.58 MiB) Downloaded 164 times
Re: Disable DoD
update has been released as 1r03g
TJEli
Re: Disable DoD
Post by TJEli »
Mike,
Did anything change between the 1t03gc file you posted and the 1r03g file that was released? I just updated my intune and it still says application version 1t03gc.
-Eli
Re: Disable DoD
to replace that file, click update/check now on the updater :)
it is the same however.
dbroylz
Re: Disable DoD
Post by dbroylz »
Do I have to restore the factory tune before I update? I know I did when I had a predator.
TJEli
Re: Disable DoD
Post by TJEli »
No. Update and reinstall.
dbroylz
Re: Disable DoD
Post by dbroylz »
I updated it last night and reloaded it to my truck. Will find out this morning if it worked.
dbroylz
Re: Disable DoD
Post by dbroylz »
Problem solved!! Thanks guys for the help.
