Help with U7137 (transmission to tool failed )
- adventurer
Help plz , while updating tool to crom 9r14 the tool gave me file missing or corrupted so i went to the help on DSD and done exactly what it says it works till the mid or less sometimes of the downloading then it stops and give me the message transmission failed i tried on another lao top and it gives me the same , NEED help please am trying this all day and i get the same
( 1 ) 2010 RAM HEMI CC/ S&B CAI/87MM TB/JET 180 TSTAT/HKS TB GW/OIL BREATHER FILTER/Y PIPE/PYPES VIOLATOR MUFFLER/DS CUSTOM TUNE.
( 2 ) 06 Ram QC hemi 4x4 SLT, Sport , Magnaflow cat-back ,Y pipe , Poweraid TB spacer, HKS TB GW, SRT8 Mopar CAI, DS Custom tune, Oil breather filter, Jet 180 Tstat.
Re: Help with U7137 (transmission to tool failed )
this can be a tough one, best bet would be to give us a call with it all hooked up to the PC please.
- adventurer
I am outside us so it will be international call can u provide a number to call or can u solve it without calling ?mikel wrote:this can be a tough one, best bet would be to give us a call with it all hooked up to the PC please.
open dsdl
click send tune file to tool
select crom
'tool is ready to download', click Yes.
On the next screen, that shows the progress bar and says sending packets, immediately click the red X there and cause the program to crash.
let the tool sit for a minute, it should say 'installing bootloader' on the screen.
from there, open dsdl, and resend the crom file, and it should work.
select crom
- adventurer
did that and the same it reaches third green bar then same msg transmission failedmikel wrote:open dsdl
select crom
try redownloading the file from our site?
- adventurer
i did that 3 times Mikelmikel wrote:try redownloading the file from our site?
what is the file size on your PC?
try this file:
try this file:
- u7137-9r13.crom
- (2.86 MiB) Downloaded 284 times
- adventurer
2.75 mbmikel wrote:what is the file size on your PC?
try this file:
- adventurer
didnt work mikelmikel wrote:what is the file size on your PC?
try this file:
cable issue?
does it fail at the same spot each time?
- adventurer
not cable issue i tried 2 cables, and no it doesn't fail at same spotmikel wrote:does it fail at the same spot each time?
- adventurer
I tried every thing , now the pc not seeing the tool, i lost the canned tunes and 3 custom tunes, now my predator is useless .....
Id suggest sending the tool in so we can fix it for you.
