intune says an error has occurred 12002
hemi04345
Post by hemi04345 »
I've done everything stage manual and what the website says and followed some other fourms said and still getting no where. It won't update and it says error 12002 .I plugged it to my truck and it says it needs a update to unplug it and update it. I have a 2004 Dodge ram 1500 5.7 hemi, help me I want this thing to work. I see so many things wrong with the I tune. Is the trinity having the same problems?
Ill_Born_SS
Re: intune says an error has occurred 12002
Post by Ill_Born_SS »
The 12oo2 error is due to your firewall I believe. You have a Dodge so when it tells you to update after connecting to your truck it means it needs to disconnect from the truck and re-connect with the computer to download a new calibration for your truck and then you must go back to the truck and apply that update prior to any tuning.
" Just Friggin Wicked"
Now with TCM support...
hemi04345
Post by hemi04345 »
OK if my intune us not updating when I connect it to my PC where do I go to download a new calibration for my truck? and then how can i go back to the truck and apply that update prior to any tuning.?
hemi04345
Post by hemi04345 »
Where can I find s calibration for my truck ?
hemi04345
Post by hemi04345 »
Does this mean ima have to purchase one them to get the I tune to work on my truck? I called tech support but can't get thru.
hemi04345
Post by hemi04345 »
I have a I tune not the predator
the cal update is done by simply connecting to a PC and letting the intune.exe run and it will d/l the file for you.
hemi04345
Post by hemi04345 »
I've hooked it to my PC a few times and when I do it loads with a red bar on the I tune and it goes to the I tune updater and it comes up with error 12002
Ill_Born_SS
either you have no internet or the firewall will not allow you to connect.
yes, that is generally a firewall issue.
post the info.xml file here please.
hemi04345
Post by hemi04345 »
I don't know much about computers what do you mean firewall issue??
hemi04345
Post by hemi04345 »
OK if I updated my I tune and I'm up to date. And I hook it to my truck and it reads and logs my truck and when I got to tune my truck.it don't give me the adjustable parameters position then what is going on now?
to adjust params, pick the tune, then choose the option to modify that tune.
hemi04345
Post by hemi04345 »
It won't.let me choose that option.
