Tire Pressure Waring Light Jeep Wrangler
midevil214
2010 JK Rubicon. I set the U7137 Predator tire psi threshold to 0 and aired down. The waring light on the dash still came on. It blinked for a while and then went solid. I thought the pressure adjustment parameters were supposed to keep the dash light from illuminating. Doubled checked and there are no trouble codes. Does it take a 5-10 key cycles to get it going?
Re: Tire Pressure Waring Light Jeep Wrangler
are the sensors in place?
midevil214
No we switched to different wheels with standard valve stems. I thought setting the threshold to zero would take the sensors out of the loop.
nope, thats just a threshold, cant disable them.
midevil214
Bummer! I figured setting it to zero would turn off the TPMS like the AEV Procal and the Flashpaq. Wish I would've known this before I declined to have my TPMS sensors swapped to the new wheels.
Explain to me why a 700$ programmer can not turn it off but a 99$ (AEV Procal) can ?
That makes no sense. Ill be happy to help . I own both.
Eat. Sleep. JEEP.
2011 Jeep JKU - D60's
