Best MPG tune for 03 Dodge RAM 1500 Hemi?
Posted: Tue Feb 26, 2013 7:04 pm
by schwally
Is the best mpg going to be the mileage booster, or will it be better with running a premium fuel & premium 91 tune, or other? Also, if I run mpg tune, can I specify 87, 89, 91? Which would give the best mpg? Hope that makes sense.
Re: Best MPG tune for 03 Dodge RAM 1500 Hemi?
Posted: Tue Feb 26, 2013 7:27 pm
final MPG is heavily dependent on driving style, best bet is to try a tank of each tune and see which works best for you.
If mostly highway, the MPG booster tune is the best option.
Posted: Tue Feb 26, 2013 7:50 pm
by schwally
Sounds good, thanks. Also, am I able to select the grade fuel if I use the mpg tune? Or is it stock to 87?
Posted: Wed Feb 27, 2013 11:15 am
mpg tune is for minimum of 87 on the trucks.
Posted: Wed Feb 27, 2013 10:23 pm
by AZHEMI
I had a custom tune for both mpg booster and performance tune as well as a trans tune--- the custom tunes work way better if you add any other power adders like a CAI, exhaust etc..... I used TSS for mine prices were fair
Posted: Thu Feb 28, 2013 11:21 am
by mbehr55
I'm testing the MPG Booster tune on my 05 2500 w/hemi and auto. So far it has not been any better than stock (finishing up my 3rd tank). Going to test the 87 performance tune next (fillup is tomorrow). Hope that shows improvement. :drivingbad:
Posted: Fri Mar 01, 2013 1:36 pm
by AZHEMI
mbehr55 wrote:I'm testing the MPG Booster tune on my 05 2500 w/hemi and auto. So far it has not been any better than stock (finishing up my 3rd tank). Going to test the 87 performance tune next (fillup is tomorrow). Hope that shows improvement. :drivingbad:
if you have any power adders like a cai or exhaust you will need to get a custome tune to take full advantage of the gains on the rams. I asked this question a year ago and did alot of digging into it and the pcv system is set up different-- i know over at TSS if you want to mod the canned tune its like $30 for that and that will tweek it for your power adders if you do have them--- when i first started i got better fuel eco with the perf tune then the MPG booster tune. But theres alot of contrubuting factors to fuel consumption- driving style, weather, idle time etc....
Posted: Sun Mar 03, 2013 10:11 am
by mbehr55
My 05 Ram is bone stock. I don't plan to spend more money for a custom tune unless somebody has good stats to backup a recommendation. I'm posting my results at dodgeforum.com.
Posted: Thu May 09, 2013 4:33 pm
by bighemitex
when did the 2003 get the mpg booster tune? when i was still using the tunes on the hand held there wasn't an option for it.
Posted: Sat Jun 29, 2013 8:07 am
by Zxalfiezx
Does TSS have a website? I also have an 05 ram hemi with cai, etc.
Posted: Sun Jun 30, 2013 6:46 pm
by AZHEMI
http://www.tuningsuperstore.com/
Zxalfiezx wrote:Does TSS have a website? I also have an 05 ram hemi with cai, etc.
