Is it possible to disable auto upshift with a 11 Challenger?
hewiga
Post by hewiga »
I see the menu item to raise shift points, but have not found a way to completely disable auto uphifts while in autostick mode with my 2011 Challenger. Or is there a way to specify the upshift RPM beyond the standard/raised option?
Do I just need new glasses or is this not an option for the 2011 Challenger? And if it is not available now, when will it be an available option.
Thanks.
hewiga
Re: Is it possible to disable auto upshift with a 11 Challen
Post by hewiga »
The car is a 392.
Not sure why other questions get answered but this one gets ignored. I have been on the forum for a while and have never seen a direct answer to this question. I would appreciate some sort of response. Even if it is 'no you can't do that' or 'we are working on it'.
you dont have the auto stick settings in the quick adjust menu?
hewiga
Post by hewiga »
mikel wrote:you dont have the auto stick settings in the quick adjust menu?
The only setting I have is 'raised' or 'standard' for shifting. I can not set specific shift point rpms or disable the upshifts.
hewiga
Post by hewiga »
bump... ???
hewiga
Post by hewiga »
Is it possible to completely disable auto upshift with a 2011 Challenger SRT8 Auto? I see nothing in any of the menus.
If the answer is yes, where is the menu to do it? I can not find it anywhere.
If the answer is no, then will this feature ever be added in the future?
