ford lightning
Posted: Thu Feb 28, 2013 9:30 pm
Hello I was just wondering about the tunes that come with the itune. I have 01 ford lightning when you look at the product search area it lists the intune tunes for the ford lightning.
91 Octane Performance
This tune is designed for use with 91 octane for the premium fuel available in many states. The Performance Tune will unleash the maximum available Horsepower, Torque and Economy out of your stock vehicle with no other mods necessary! Vehicles will see a power across the entire RPM range with the greatest gains down low. Vehicle will also see improvements in drivability, throttle response, and economy 35 40
91 octane pulley prewritten dyno tune for 99-01 Lightnings with a boost increase via pulley upgrade for total of 13-14 psi boost, and 91 octane fuel
45 50
91 octane 90 mm MAF
Prewritten dyno tune for 99-01 Lightnings that have upgraded to 2002-2004 90mm MAF sensor, and 91 octane fuel 40 45
91 octane pulley/90 mm MAF Prewritten dyno tune for 99-01 Lightnings that have upgraded to 2002-2004 90mm MAF sensor, and boost increase with a pulley upgrade for total of 13-14 psi boost, and 91 octane fuel 80 95
Modified Stock
This will allow you to keep the vehicle at the stock horsepower and torque levels, but the user can still change all the available adjustable parameters for the application, like the speed limiter, speedometer calibration, etc.. Modified Stock also allows you to ?marry? the tool to the vehicle and make a copy of the stock tune when requested by a CMR Dealer (custom tuner). NA NA
I was woundering why some of thise dont show up when go to flash the truck it only shows 91 performance , then 91 with pulley there is no pulley and MAF option or just the 90 mm MAF also if you install the 91 performance do I need to redo the flash when I go to add a 90mm maf sensor. My Intune is fully updated
45 50
91 octane 90 mm MAF
Modified Stock
