MDS disable and rev limiter
Posted: Fri Mar 01, 2013 2:32 pm
by ctmoore778
On my '12 Challenger RT, I installed a 91 tune with shift firmness, rev limiter bumped to 6100, and the MDS disabled but I can still feel/hear the cylinders shutting off. Is this a known issue or anyone else come across this as well?
I also have a question about the rev limiter... is it supposed to take effect in D on an automatic transmission or is it only when using the click-shift? It's definitely not working while in D at the moment. I'm wondering if my entire tune with my options never went through or if these are just not working as intended.
info.xml
PCM_05156128AD_Backup.drg
PCM_05156128AD_LastTuneWritten.drg
Re: MDS disable and rev limiter
Posted: Fri Mar 01, 2013 2:48 pm
ctmoore778 wrote:On my '12 Challenger RT, I installed a 91 tune with shift firmness, rev limiter bumped to 6100, and the MDS disabled but I can still feel/hear the cylinders shutting off. Is this a known issue or anyone else come across this as well?
info.xml
are you sure it was set to off, then the tune was installed?
its off here....
Posted: Sat Mar 02, 2013 1:45 pm
by ctmoore778
I first installed the 91 tune without any parameter changes. Once this successfully went through, I made the parameter changes including rev limit to 6100, MDS off, shift firmness on, and throttle boost +5%. Then this rewrote the tune and it said it completed successfully. I'm not sure if this answers your question or not, but when I changed the parameters, I definitely had MDS set to off.
Will the tune you provided allow me to make my other adjustments?
Also, any info about the rev limiter question?
Posted: Mon Mar 04, 2013 12:21 pm
we have identified this issue, and will be releasing a fix soon.
you wont be able to adjust params in that tune yet.
