93 octane tune and aftermarket waste gate
Posted: Sat Mar 02, 2013 9:15 pm
by Flakdodger
Put the 93 octane tune in with the stock pcm. Seems to run better. Concerned about the weak stock wastegate and want to upgrade to a aftermarket but I see they state aftermarket not recommended with Predator/trinity 93 octane tune without getting a custom tune.
Is this true?
Re: 93 octane tune and aftermarket waste gate
Posted: Mon Mar 04, 2013 12:58 pm
Posted: Tue Oct 06, 2015 10:17 pm
I'm having the same problem. Can u give us a yes or no?
Posted: Wed Oct 07, 2015 12:12 pm
its a pretty clear yes, you need a custom tune.
Posted: Thu Oct 15, 2015 11:24 pm
by SHFTQIKR
mikel,
I know that the Base 93 tune says not to use a heavy spring WGA like the AGP, but can you use an AGP with an 8lbs spring? Wouldn't this be similar to a mopar stage 2 WGA? Also is the 93octane tune based on stock injectors (2004 NSRT4), WGA, tip &map sensors, or is it more focused around stage 2 upgrades like the 682cc injectors, WGA, & tip sensor?
Any help clearing this up would be greatly appreciated, as I very much want to purchase a Trinity unit, but srtforums responses seem to muddy the water on the subject.
SHFTQIKR
