tune options 06 silverado 2500 hd with the 6.0
Posted: Sun Mar 03, 2013 1:46 am
by westernstar
so i have to diablo pcm tunes and a 87 octane.What are the diablo tunes
Re: tune options 06 silverado 2500 hd with the 6.0
Posted: Sun Mar 03, 2013 8:16 am
by Ill_Born_SS
In your case the Diablo tune is for 91 or better octane fuel, if you had a separate 91 tune then the diablo tune would be for 93 octane or better.
Posted: Mon Mar 04, 2013 7:36 pm
by westernstar
it shows this
diadlo tune
87 octane
diablo tune
modify stock
Posted: Mon Mar 04, 2013 7:43 pm
by westernstar
also it will allways do an update after it says its updated and can i adjust trq management it only has on and off.what tunes are avail for the 06 silverado 6.0 getting frustrated with this tuner.also there is no gear change setting
Posted: Tue Mar 05, 2013 11:28 am
what exactly are you frustrated with?
We're here to help, we'll answer any questions you may have.
Posted: Tue Mar 05, 2013 12:21 pm
by westernstar
Every time I try to update it wont update to the new update for gm tunes
Posted: Tue Mar 05, 2013 3:37 pm
westernstar wrote:Every time I try to update it wont update to the new update for gm tunes
please post the info.xml file and I'll check out the current versions.
Posted: Wed Mar 06, 2013 6:17 am
by westernstar
K it updated now but now has 2 modify stock tunes 2 diablo tunes and 87 octane tune and stiil no gear change option
Posted: Wed Mar 06, 2013 10:39 am
the axle ratio param may be missing, if you need it adjusted, please post the tunes from your tunes folder on the intune drive and I'll set it up for you.
Posted: Wed Mar 06, 2013 10:47 am
by westernstar
Sounds good just curious what are the 2 diablo tunes
Posted: Wed Mar 06, 2013 3:49 pm
there shouldn't be 2 diablo tunes...
should be an 87 Octane Tune... and a Diablo Tune (which is for 91+ octane)... and the modify stock tune... that's it...
if you have 2 Diablo Tunes listed, then sounds like a bug/issue... have never seen/heard of that one before....
Posted: Wed Mar 06, 2013 4:09 pm
by westernstar
Ya I figured something was wrong 2 diablo 2 modify stock and 87 seemed weird would a for cal fix this and wondering if there is a mileage tune coming out
Posted: Wed Mar 06, 2013 8:34 pm
by westernstar
also inable to download dslogredux keeps telling me cant be found??
Posted: Wed Mar 06, 2013 9:22 pm
by westernstar
Never mind got it now lol
Posted: Fri Mar 08, 2013 11:36 am
I would update that intune to see if that double tune issue gets resolved... if it doesn't, then I'd call tech support and see what's up about that before doing anything else..
