Error code P0605
Error code P0605
Hi,I installed it on my 2006 mustang gt map for the filter jtl following all the steps, at the end of the mapping I turn on the car and has many alarms, then carry the unit and the original filter and the car turns off when I put the D , control errors and find P0605 .... what happened? before I had this problem. thanks to all
Re: Error code P0605
have you restored the stock tune to make sure its OK?
yes, problem error eliminated with the installation of the original map,
now I have another problem, I put the car on gear D and off the engine,
engine speed seems too low... why
before install JTL tunewith predator dont have this problem?
Do you still have the JLT installed? You cannot run that intake with a stock tune.
Insert Clever comment here...
noooooooo now i have removed the JTL air intake, have a stock filter and stock tune !
