Page 1 of 2
Cannot load custon tune to Intune DCX
Posted: Tue Mar 05, 2013 7:18 pm
by anarchy
Hi,having problems here,hopefully someone can elighten me. First thing im going to say,is I dislike the Intune. Ive used several and each one has given me some kind of grief,wether it updates for hours on end or freezing up and what not. So I have a Intune DCX here. First problem it gives me is when i loaded the diablo tune into a 2011 challenger RT, The pcm freezes up after flashing and has no response to key cycles.Ok so after the intune goes into recovery mode and flashes back to ORI after disconnecting the battery,It happens everytime i try to flash with intune. So i leave the Intune hooked up to my laptop so it is powered up after the PCM locks up and disconnect the battery,reconnect and finally it will verify the tune without going into recovery,problem solved I guess. So This car got a procharger and I built a custom tune for it. I keep a Trinity personally,that i use to build tunes with,cause they work so nice and fast. I have no issues flashing with the Trinity on this car. So i built the custom tune using the trinity and get it done. Now I know the Trinity and intune file formats are different(I found this out the hard way before). So I flash the 2011 chally with the intune again to get the the ORI. I take the intune ORI and apply the supercharger calibration file made from the trinity tune and apply it to the intune ori and save it. For whatever reason when i drag,copy,cut the tune into the intune folder, the intune never asks to import the file,and it does not show up as a custom tune,but it is in the folder. What am i doing wrong? Please dont say it is because of the trinity cal file,because I used this same method tuning a srt4 without a problem. Thanks Jesse
Re: Cannot load custon tune to Intune DCX
Posted: Tue Mar 05, 2013 7:38 pm
id try deleting the file from the drive, reboot the tool, and then reload the file to the drive, it should import fine.
I had another tuner earlier today with the exact same issue, and for some reason he had to switch PCs to get it to import the file...are you maybe running Win8?
Id also make sure the tool is fully updated, 1r03h is current.if cmr is installed, the updater will lie to you and say the tool is up to date, you can click update/check now to confirm.
Posted: Tue Mar 05, 2013 7:44 pm
by anarchy
You were correct about the update, said it was up to date,but i checked like you said and it is updating as i type. I will post back shortly.
Posted: Tue Mar 05, 2013 7:54 pm
by anarchy
The Intune dcx finished updating,and right away it said Custome tune file uploaded. Gonna try to get in the car now. If you dont hear back from me,assume everything is good. Thanks Again Mike. Jesse
Posted: Tue Mar 05, 2013 8:07 pm
by anarchy
Ok tune loaded,but still having that pcm lock up issue after flashing. You turn the key off,but it wont cycle back on. If your reading this,make sure you have the intune plugged in via usb,it could probably be done with just a phone charger,then disconnect the car battery and reconnect. This will reset the PCM, so it will power back on and finish verifying the tune. If you dont hook up the intune to an external power source,it will just shut off when you disconnect the battery,and forever be stuck in recovery mode until you do use this method. Hopefully this will help someone and save some aggravation,thinking your pcm is bricked,until this problem is fixed. Jesse
Posted: Tue Mar 05, 2013 8:25 pm
by Ill_Born_SS
"then disconnect the car battery and reconnect." have you tried it just pulling the pcm fuse instead of a complete disconnect?
Posted: Thu Mar 07, 2013 5:29 pm
by anarchy
And thats a better idea. Guess I didnt think of that out of being completely pissed off at the time. I have to do that to gm TCM's after reading. Thanks for the input.
Posted: Fri Mar 14, 2014 5:59 am
This is what i am going threw i did a twin turbo build ..just got the full tt build compleated went an got a custom tune written for the new forced induction/my new set up go to plug it in and do a key cycle and it kicks me back to home screen and gos in to recovery mode car wont crank/turnover/start...and used my other code scanner and it threw a U0100 lost com. With ecu/pcm so now i dont know whats goimg on :/ very Frustrating because it ran perfect before I did the build ... And i to am thinking my comput. Is fryed but i am Going to check and tried to do the battery disconnect with computer thing and see if that will work and if it will crank or start Anybody's and put would very much be helpful thank you so much you guys by the way car is a 05 dodge magnum Rt 5.7 tt76mm ...using the diablo intune ...
Posted: Fri Mar 14, 2014 9:44 am
[email protected] wrote:This is what i am going threw i did a twin turbo build ..just got the full tt build compleated went an got a custom tune written for the new forced induction/my new set up go to plug it in and do a key cycle and it kicks me back to home screen and gos in to recovery mode car wont crank/turnover/start...and used my other code scanner and it threw a U0100 lost com. With ecu/pcm so now i dont know whats goimg on :/ very Frustrating because it ran perfect before I did the build ... And i to am thinking my comput. Is fryed but i am Going to check and tried to do the battery disconnect with computer thing and see if that will work and if it will crank or start Anybody's and put would very much be helpful thank you so much you guys by the way car is a 05 dodge magnum Rt 5.7 tt76mm ...using the diablo intune ...
is the tool fully updated?
give us a call with it plugged into the vehicle and we'll get you going.
Posted: Fri Mar 21, 2014 7:10 am
Yes it in now fully updated¿.. And i spoke with mike on the phone(i Believe you?) ..got it fully updated and outa recovery.. And now that its back i still cannot get it to install the tune:/ i click the top icon.. I believe it's"Load new tune"Or load tune? Anyways I click on that And it bounces me back to the home screen?? So basically still nothing is changed Other then The handheld now being out of recovery mode(Mike did over the phone and over the computer and updated) .. But now I am worried that it somehow bricked my ECU.. I've spoken with other people And they said that is there fear..
.. Very disappointed that this can even happen I would really appreciate anybody and everybody's input And Mike at Diablo I would very much appreciate it if you can try to help me get this thing started As I am out my car/Daily driver....i have added nothing big electrical? Actually the Entire Twin turbo build was Mechanical.. The only thing At all shape or form electrical was the tea taps for the pen style turbo timer.. Even the boost controller is a manual mechanical controller
people are saying that If it didn't flash correctly or lost/low voltage Then I could have bricked my ECU.. And it saying lost communication to EC you on my normal check engine light scanner Is what is making people say this?? So please Mike help let me know I will be here Also here's my email address
[email protected] ---so please help me i have a 30k car sitting here dead in the water:/ just very Disappointed:(
Posted: Mon Mar 31, 2014 6:27 am
Help please?? I just had to buy a new sheep car for work and stuff i have ro get this figured out? Still wont crank/start?? Even after mike did the updating and cleared the protection mode and it wont alow me to right a tune on it? Im sos scared it bricked my ecu? Thats what everyone is saying because It doesn't have any tune on the ECU right now so please help me i didnt even know that This incident couldn't actually even happen I was never told by anybody or anything on the Diablo sport Website and directions or anything like that If I wouldn't do that I would've just took it somewhere But I never had a problem before when I was just doing normal tunes so please help me Did Diablo Sport Antoun every time I try to write a tune I go through the key Rotation and then out of nowhere kicks me off back to the first page with the three icons So please help Because as of right now I have a $30,000 brick :/
Posted: Mon Mar 31, 2014 9:36 am
is it still throwing codes?
post a fresh copy of the info.xml file please.
Posted: Tue Apr 01, 2014 8:16 am
What are u asking for? Nothings changed since last time i spoke to the mike guy and he took over my computer and got me my intune all updated and out of recovery mode and said i should be good to go ...
Well Obviously not my car still wont turn over or start im very frustrated like i said and said it wont alow me to install a tune on the car now?? And says Los communication ECU so still at square 1 iv had some simi inclinded car guys look at it and they think it bricked my ecu or some how fryed it ?? Sor idk what to do??no body iv talked to in my state will even let me tow it in to help me man:( my proformance car shop said they cant dodge said no do to It being so highly customized the moddedso please help me please last time he wouldnt wIt with me on the phone to try just said i should be good and im not !?? I need this thing back running please help me??
Posted: Sat Apr 05, 2014 5:56 pm
??? Well ?? Anyhelp please???
Posted: Mon Apr 07, 2014 12:40 pm
can you post the info file?
can you describe what happens if you try to tune the vehicle right now?
