Installed intune on 2010 silverado...
Doesnt seem to be much difference. Installed 87 tune, turned speed limiter off and torque management off with mid firm shift ad justed for tire size. what i dont like about it is it seems to have a delay b4 it shifts hard. Is there anyone/anyway to adjust and make better? anyone have tune or no of good settings for these trucks? 2010 5.3 z71 4x4 i have intake and exhaust
Re: Installed intune on 2010 silverado...
What i would like to have
Good 87 tune
Good 93 tune
Good 87 towing tune
Good 87 tune
Good 93 tune
Good 87 towing tune
try the hard shift tune...
did that one 1st had same delay. Would like it to be quicker
then adjust the shift speed
ya dude put it on the diablo with good fuel and even some booster set the tranny on sport/tow put the pressure up---> at wot on the 123 it will take a few miles to learn and then be greatsiclsx wrote:Doesnt seem to be much difference. Installed 87 tune, turned speed limiter off and torque management off with mid firm shift ad justed for tire size. what i dont like about it is it seems to have a delay b4 it shifts hard. Is there anyone/anyway to adjust and make better? anyone have tune or no of good settings for these trucks? 2010 5.3 z71 4x4 i have intake and exhaust
BlackZ71Silverado
Add Booster??? What do you mean by that?hoorsec wrote:ya dude put it on the diablo with good fuel and even some booster set the tranny on sport/tow put the pressure up---> at wot on the 123 it will take a few miles to learn and then be greatsiclsx wrote:Doesnt seem to be much difference. Installed 87 tune, turned speed limiter off and torque management off with mid firm shift ad justed for tire size. what i dont like about it is it seems to have a delay b4 it shifts hard. Is there anyone/anyway to adjust and make better? anyone have tune or no of good settings for these trucks? 2010 5.3 z71 4x4 i have intake and exhaust
OP, don't set your transmission to TH mode. All you need to do is adjust things until you get them to where yo uwant them. Install the tune you want, adjust the transmission a little bit and drive for a while. When the truck learns that tune, change the settings if you need to. It may take a little time for you to get things exactly where you want them.
Also try bumpint the shift points up by 100rpm's, that will also make a difference for you.
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
