piece of s#! t
mcginnis22
piece of s#! t
Well loaded up the calibration update from the computer, try to upload to my car (20012 challenger rt), and low and behold I get failed toupdate. Not once, not twice, but eight times. HELP!!!!!
mcginnis22
Re: piece of s#! t
It loads the calibrated update then I get to the dreaded key turns. Turn it off hit the cgeck mark then wait. Turn it to on pos hit the check mark and it says error failure to update. Turn it all off unhook it and the check engine light is on. Cleared that by undoing the battery. Am I doing the key turns wrong or what. I plugged it back up to tge computer and it tells me it is updated....haaaa frustrating.
Re: piece of s#! t
I'm having this same issue...... Always fails right at the end of the calibration update install on the car. Now mine is pretty much stuck in recovery mode.... very frustrating.
Re: piece of s#! t
please give us a call with the tool powered up in the vehicle.
mcginnis22
Re: piece of s#! t
what is the latest that I can call you because I usually don't get home till 5 o'clock and I live in Texas so I think we're different time zones
Re: piece of s#! t
we are here until 6:00 PM EST.
mcginnis22
Re: piece of s#! t
Anyone there on saturday or sunday??
Re: piece of s#! t
No, sorry, we are here M-F.
mcginnis22
Re: piece of s#! t
Ok. I will definitely be calling u wednesday afternoon.
Re: piece of s#! t
I had the same issue, when it gives you the green check either to turn on or turn off give it and extra 10 seconds each time. Its worked for me, and i have a 2012 dodge challenger rt, at least it work on the last update, ill check here in a min with this new update.
mcginnis22
Re: piece of s#! t
So your saying when the update is done for calibration and it tells you to turn your key off you give an additional ten sec then turn it off and hit the grrn check
