Modifing a Tune
Posted: Mon Mar 11, 2013 1:28 pm
by Boomer4955
If I want to modify a tune that is in the car do I need to put the stock tune back in the car then mod the tune and reload it back into the car? :lamer: Thanks for the help!!!
Re: Modifing a Tune
Posted: Mon Mar 11, 2013 10:11 pm
no.. just connect to the car.. select the same tune you had installed before.. then modify it... save/apply the changes you make, then install the tune....
Re: Modifing a Tune
Posted: Tue Mar 12, 2013 9:06 pm
by Boomer4955
Thank you! :lol:
Re: Modifing a Tune
Posted: Fri Apr 12, 2013 6:04 pm
by Technoboi
I just put in a cold air intake on my 05 magnum rt.can u show me how tune it to 91 octane on my trinty t1000
Re: Modifing a Tune
Posted: Fri Apr 12, 2013 6:19 pm
by Mike_Levy
Just pick the 91 CAI tune.
Re: Modifing a Tune
Posted: Sat Apr 13, 2013 11:01 am
by Technoboi
Step by step pls
Re: Modifing a Tune
Posted: Wed Apr 17, 2013 8:20 pm
by dguth66
06MonteSS wrote:no.. just connect to the car.. select the same tune you had installed before.. then modify it... save/apply the changes you make, then install the tune....
Hey Lew....thanks this clears it up a bit more for me....what if I had the Diablo installed and wanted to switch to say the 87 tune. Will the Trinity automatically compare write the 87 tune ?
Thinking that always reverting back to orginal backup before hand is a sure fire way but longer for sure.
by Technoboi ยป Sat Apr 13, 2013 4:01 pm
Step by step pls
Its all in the manual and also search here too....lots of info. One thing I've found that helps me learn the details of something new like this (tuning) is to keep your own living document in word....that way as you find what you are looking for you can add and make your notes as required.
Re: Modifing a Tune
Posted: Thu Apr 18, 2013 1:41 am
yes, you can just switch to the other tune if you want, and any changes you made yourself before, will be carried over... it should ask you if you want to "reset all parameters"... if you choose NO, then it will apply the changes you made before to the new tune you are installing... if you choose YES, then it will erase the changes you made before and just install the new tune with its regular settings....
no need to go back to stock first when switching tunes...
Thanks!
-Lew
- www.diablewtune.com
