no go wot!
herationkane
no go wot!
I have a 2013 gmc 6.6l duramax with the p2040 extreme power puck. with the knob turned to the max I am getting 2-3mpg better, but If I go wot in any gear past 2nd it seems to stall and power is cut. I can let off to 50-60% and it will pull again. I called the tech department today and the guy had no idea what he was doing! I think he was the floor technician! I have the fass 150 on the truck and it still is not running correctly. Please give me some ideas!
Re: no go wot!
did you install the fuel rail shim kit?
herationkane
Re: no go wot!
No sir, What is this? Where do I get it? What will it do? Thank you.mikel wrote:did you install the fuel rail shim kit?
herationkane
Re: no go wot!
I can't seem to find a shim kit for an lml. can you help please
Re: no go wot!
Just out of curiosity are you getting any indicator lights? I'm wondering if maybe you are limping it.
Re: no go wot!
its a stack of 3 washers placed behind the pressure relief valve to increase its holding pressure....the instructions are shown inthe manual.herationkane wrote:mikel wrote:did you install the fuel rail shim kit?
If you didnt get the shims inthe box, please email me your name and address so I can get it out to you.
herationkane
Re: no go wot!
I did not receive the shim kit.
herationkane
Re: no go wot!
It does not have any lights or codes. When I go full throttle it just feels like it is stalling. It actually feels and sounds like its hitting the rev limiter and when I let off some it will start to pull like it should.BigDeez wrote:Just out of curiosity are you getting any indicator lights? I'm wondering if maybe you are limping it.
herationkane
Re: no go wot!
Tonight I made 2 passes against my buddies Pontiac g8 and from start to close to 1/8 mile it pulled very hard then started acting up. On the second pass same thing then a light came on. It said low fuel pressure and lost com with glo plug module.BigDeez wrote:Just out of curiosity are you getting any indicator lights? I'm wondering if maybe you are limping it.
herationkane
Re: no go wot!
herationkane wrote:I did not receive the shim kit.
Hello mikel
Re: no go wot!
Sorry, I was out of the office Friday, I got the info over to our guys today.
herationkane
Re: no go wot!
I received the shim kit but on previous models the relief plug is in the end of the rail where the lml just has a sensor that cant be shimmed.
herationkane
Re: no go wot!
mikel, can you please find out how to make this work on an lml?
Re: no go wot!
sounds like the fuel system simply cant keep up, or its dumping fuel pressure which is what the shim kit would have been for....let me investigate.
herationkane
Re: no go wot!
Did you find a way to make this work for me?mikel wrote:sounds like the fuel system simply cant keep up, or its dumping fuel pressure which is what the shim kit would have been for....let me investigate.
