Stacking w/EGT module and feed to Trinity
The Extreme Power Puck is advertised as being used with the Trinity Programmer utilizing the T1015 optional analog wire harness. However, there is no wire diagram or instructions on how connect the EPP to the T1015. Has anyone successfully made this transition from the supplied dial switch to the T1000 programmer? I have the Diablo EGT module, the Diablo EPP and I want to run both the Diablo T1000 programmer. All documentation shows that the T1000 can handle 2 analog inputs. The EGT module has good documentation with wire diagrams. The EPP not so much.
- Ill_Born_SS
Re: Stacking w/EGT module and feed to Trinity
Read thru this: http://www.diablosport.com/forum/viewto ... 36&t=35350 The optional cable has the connector for both units on one end and the Trinity on the other. Then you must activate each on the trinity (analog inputs, EPP and EGT) there is links to at least some of it in that thread.
" Just Friggin Wicked"
Now with TCM support...
