NOT HAPPY
cam36
NOT HAPPY
Post by cam36 »
Just plugged in my DCX to my 2012 jeep wrangler, uploaded my 87 tune. No throttle at all. Try to go back to the factory tune and it keeps failing. Please help!
ROBSMST
Re: NOT HAPPY
Post by ROBSMST »
Try a quick adjust and bring up the throttle in 5% incraments.
Also isn't the 87 tune the gas saver? I would expect no throttle response.
I ran the 91 tune with + 20% throttle and 35.5 tires and it worked well. Keep in mind that's a total of 35% throttle. I averaged 15.5mpg on one tank.
Now I'm running the gas saver or 87 tune. No throttle added. Avg 15.4mpg but I took the top off and still drive 75mph on my 37" open country tires.
I think I'm going back to 91 on next tank.
Mine is a 2011 JKU rubicon wrangler. So not apples to apples but thought my exp may help.
cam36
Re: NOT HAPPY
Post by cam36 »
ROBSMST wrote:Try a quick adjust and bring up the throttle in 5% incraments.
No when I mean no throttle response I mean no throttle what so ever. I eventually flashed it back to stock but the 87 tune isn't a gas saver. It's a performance time designed to work with 87 octane. Ill try again later to upload it and play with the throttle booster
tonkajoe
Re: NOT HAPPY
Post by tonkajoe »
I also have the same issue as cam36
2012 wrangler w/ 6speed stick
when is their going to be an update for this
if it cant be fixed Im going to req. an RMA to return this
cam36
Re: NOT HAPPY
Post by cam36 »
tonkajoe wrote:I also have the same issue as cam36
Already returned mine, maybe I will give it another try when it is fully developed.
Tomiboy636
Re: NOT HAPPY
Post by Tomiboy636 »
This really sucks monkey balls to be the beta tester for crappy product! FFS! :blowup:
Re: NOT HAPPY
cam36 wrote:Just plugged in my DCX to my 2012 jeep wrangler, uploaded my 87 tune. No throttle at all. Try to go back to the factory tune and it keeps failing. Please help!
load the tune and post a copy of the ltw here pelase, and I will provide a simple fix.
You can email it to me at mlitsch @ diablosport.com to make it even quicker.
