I need more help
Posted: Fri Mar 22, 2013 11:27 pm
I purchased one of your Intunes for my 04 Chevy Tahoe. I do have some questions...
Your "Quick Start" was not very helpful and your online manual left me with more questions than answers.
On your "Quick Start" Why is it when you do your first download the computer screen tells you not to unplug the Intune, but the Intune itself only has the main screen on it, and never indicated whether or not it downloaded anything. I let the Intune sit there for over 2 hours because I was afraid to unplug it. I sent an email to your tech support and never received a response. I finally unplugged the Intune, even though my computer screen said not to unplug it. It did not indicate if it had ever rebooted.
I would imagine since this one I have was built in Jan 2013 it had no updates, but you can't tell if you just read the computer.
I asked you if this tuner will adjust for cold air intake, cat back systems, different size wheels and tires, and you said yes to all. The only thing I could find on the programmer was an adjustment for tires and wheels. Where are the adjustments for the rest?
I found these adjustments; what are they for:
Torque Management
CUT enable Temp
Injector Slope
Up shift Torque reduction
WOT for fuel and spark
Up shift MPH USTP
The Forums I went to did not really explain what they were for. If I use part of them, how does it affect the Tune I am using?
Where on your web site does it explain all these parameters? Some of the Forums stated you did not need to use them, then why make them available?
Your online manual shows 3 different octane levels; why does my tuner only show 2?
If you put the "Canned Tune" on the vehicle, how long does it take to take effect? Does the vehicle's computer have to learn the new program?
I have more questions, but this is as far as I have gone with the tuner. I look forward to your response.
Torque Management
CUT enable Temp
Injector Slope
Up shift MPH USTP
