pcm registration
Posted: Sun Mar 24, 2013 8:40 pm
Hello all,
I just recently purchased an intune I1000 for my '05 dodge ram SLT 4.7L. I had an older superchips 3815 tuner installed on my truck and I figured I needed a newer more updated version. So instead of going to the updated version of the other tuner. I have heard good things about this one and decided to try it. Little to my knowledge that I would be having so many problems just trying to get it to work!I uninstalled my other tuner and returned the truck completely to the stock setting,I checked this 3 times with the other tuner.I updated the intune I1000 like the instructions said I should on my computer and went about installing it. when I plugged it in,It did it's normal boot up thing and got to the part where you pick write vehicle and it proceeded to do its thing. then it said it needed a pcm registration update for my vin# with an X or a check.If I hit the check it told me to update it on my comp and rebooted itself. If I hit the X it went into where I could program the tranny and a couple of other things but not put any tune on my engine.I went back to my computer and tried to update it.it said that everthing was up to date.I tried this 3 times also.I went back to try to program my truck and it had the pcm registarion update error again.If y'all could please help
I've been reading other posts and been seeing that you need the info.xml file? I going to try and attach what I think it is.
Thanks for any help you can provide
