update
Posted: Wed Mar 27, 2013 10:53 am
by randyc
any ETA on the update coming to fix the 07 Silverado problem?(abs issue)
Re: update
Posted: Wed Mar 27, 2013 11:16 am
randyc wrote:any ETA on the update coming to fix the 07 Silverado problem?(abs issue)
restore the stock tune. drag/drop this to the intune drive, let the tool reboot, then load the tunes.
Re: update
Posted: Sun Mar 31, 2013 3:25 pm
by steelo
I was able to adjust the tire size, not by how tall the tire is, but by the width, aspect ratio, ad rim size, and have not had the light come back on since. I did not touch the gear size.
Re: update
Posted: Mon Apr 01, 2013 11:33 am
good to hear
Re: update
Posted: Mon Apr 01, 2013 5:11 pm
by steelo
That could be the solution to any issues people still might be having with the 07. Don't touch the tire size, but do it the way I did.
Re: update
Posted: Mon Apr 01, 2013 11:11 pm
by KBacon
I just got my Intune today for my '07 Sierra 5.3...
And after updating today.. I tried setting it to 87 Octane.. Firm shifts.. DoD delete.. tq management -10% 1-2 & 2-3... also set tire size to 275-65-18
and about 2 miles into my test drive I got ABS & BRAKE lights & lots of dinging... came back and cleared codes & went for a test drive again.. and got the same thing at the exact same point in my test drive...
So is the solution to skip the tire size correction???
Re: update
Posted: Tue Apr 02, 2013 1:33 am
by steelo
KBacon wrote:I just got my Intune today for my '07 Sierra 5.3...
It worked for me. I have noticed that the ones that can't get rid of that light are adjusting by how tall the tire is. Try it with the other option of Width/Aspect Ratio/Rim Size and see if that helps.
Re: update
Posted: Tue Apr 02, 2013 1:44 am
by steelo
Sorry, I misread your post. What I did may or may not work for others. I adjusted the tire and wheel size after I downloaded all of the updates. Maybe try to restore it back to stock, and then retune it. I would not recommend touching the final gear. Even though my truck has a 3:73, the tuner defaults at 3:72. Don't even worry about messing with that, unless you did a gear swap.
Re: update
Posted: Tue Apr 02, 2013 8:53 am
by KBacon
mikel wrote:randyc wrote:any ETA on the update coming to fix the 07 Silverado problem?(abs issue)
I downloaded this to the intune.. hoping it fixes my issues...
Re: update
Posted: Tue Apr 02, 2013 4:50 pm
by KBacon
The above update did fix my issue!!! And the truck is running awesome with the 87 tune
Re: update
Posted: Mon Apr 08, 2013 8:54 am
by randyc
I think it worked, will do a long drive today, but when I loaded this weekend and tested had no missues after I installed correctly. (did it wrong the 1st time).
Thanks Mike for not giving up on this...............
Re: update
Posted: Mon Apr 08, 2013 10:54 am
enjoy
Re: update
Posted: Tue Apr 09, 2013 9:58 am
by randyc
did a lot of driving yesterday..........................definately fixed!!!!!!!
very pleased......
Re: update
Posted: Tue Apr 09, 2013 11:29 pm
NICE!! woohoo!!
