Transmission Firmness Write Failed
Posted: Sun Mar 31, 2013 3:26 pm
by pdimarco
2012 Charger R/T. I had the 91 tune already loaded and made parameter mods such as turning off MDS and adding Throttle Boost. So all I did was go into Modify Tune and selected Transmission Firmness.
The tuner went through the build tune process and then proceeded to the write. It went through about 3 cycles of turn ON and Turn OFF ignition during this write phase. It then decided to provide the message, Write FAILED.
Tuner installed original backup. I then re-installed the 91 tune with the MDS off and Throttle % of 10. This write was SUCCESSFUL. I left as is to get some feedback.
Re: Transmission Firmness Write Failed
Posted: Mon Apr 01, 2013 11:45 am
is the tool updated to 1r03h?
Posted: Mon Apr 01, 2013 7:12 pm
by pdimarco
mikel wrote:is the tool updated to 1r03h?
I dont know. Because when I connected the intune to my computer, before I can look it updated to 1r01o.
So now the unit has version 1r01o. Should I try Transmission firmness option again with this update?
Posted: Wed Apr 03, 2013 11:14 am
by Sleeker8300
Im having the same problem on my 2012 charger. But my intune is running on 1r03h.
Posted: Wed Apr 03, 2013 8:00 pm
by pdimarco
Mike can you let me know what to do here?
My system has the latest update, so is it OK to give it another try?
Posted: Thu Apr 04, 2013 9:56 am
please post a copy of the info.xml file from the intune drive.
Posted: Thu Apr 04, 2013 7:01 pm
by pdimarco
Attached is my info.xml file.
Posted: Fri Apr 05, 2013 2:45 pm
by pdimarco
Mike,
Have you looked at the file you requested?
I have an update:
I restored my stock tune and then re-installed the 91 tune. However before writing the 91 tune, I modified the parameters including Shift Firmness and Disabled Traction Control.
The tune built and then wrote to the PCM without any issue. TCM is off because I smoked the tires at WOT.
But, and a big But...The Brake light, Traction control lights and some other dash light remain on after starting the car. I also dont really feel much of a difference in the shifting, although the inTune has a * next to Shift Firmness as though it were modified. So two things
1) Why are those dash lights still on?
2) What differences in shifting should I notice?
Posted: Fri Apr 05, 2013 3:13 pm
Its all up to date, should be fine.
The lights are normal with TC disabled, as it disables ABS as well.
