deactivate TCS & ESP
Posted: Mon Apr 01, 2013 6:04 pm
by typan
If I’m to fit a SRT LSD to a 300C 5.7Lt do I need to deactivate any TCM controls like traction control or ESP?
Re: deactivate TCS & ESP
Posted: Tue Apr 02, 2013 10:57 am
by Mike_Levy
Shouldn't have to. If you do you're gonna lose ABS and EBD too. You're changing the whole rear end, right? Because I don't think a 215mm LSD and gear set is gonna fit the stock 210mm housing.
Posted: Tue Apr 02, 2013 3:55 pm
by typan
I'm thinking of changing the complete thing, I found one with the same gear ratio 2.82:1 and the only difference is mine has a standard diff center and the SRT have a LSD diff center. I thinking what’s the difference in the electronics control, more so the traction control system going from a standard diff to a LSD diff.
Posted: Tue Apr 02, 2013 4:13 pm
by Mike_Levy
Electronics should be the same. The only difference I can think of is that the standard rear would have the electronic LSD where the brakes slow the spinning wheel so the other will engage, and the LSD one wouldn't need that. Don't think it would be an issue though, because if the mechanical LSD is working, the slower wheel should be getting power anyway.
Posted: Wed Apr 03, 2013 1:39 am
by typan
That sounds about right Mike, thanks
