Adjustable parameters button not working
marcchoquette
After much waiting I finally got my Intune fully updated but for what ever reason my ADJUSTABLE PARAMETERS function is not working and the buttun is off color. Is there some other update I am missing or should I remove the tune and install the stock program then try to reinstall it? All other fuctions seem to be working.
Re: Adjustable parameters button not working
What type of vehicle?
Insert Clever comment here...
- 06 300c ya
I am having the same exact problem. I even tried installing the cai tune again, but it would tell me it already has a Diablo tune and to connect to a PC, which I did. It went through and updated everything. However, it did not change anything at all. The only thing I can do is quick adjust on the transmission.marcchoquette wrote:After much waiting I finally got my Intune fully updated but for what ever reason my ADJUSTABLE PARAMETERS function is not working and the buttun is off color. Is there some other update I am missing or should I remove the tune and install the stock program then try to reinstall it? All other fuctions seem to be working.
Car is an 06 300C.
2006 Chrysler 300C: Cherry Bomb Vortex Cat-Back, Frankentake III CAI, 180 t-stat, Catch Can, Intune CAI Tune, Tranzformer shift kit
- 06 300c ya
ANYONE?????
that button is not yet enabled....
marcchoquette
Which button is not yet enabled? It worked before I did the update to my Intune! I have an 05 Crown Vic Sport with a tune installed and can't do a thing with it since I updated. Can anyone suggest a solution?
the adj param button, like the title of the thread....it has never been enabled.
You can get to the params by selecting the tune then choosing the option to modify the tune.
marcchoquette
Ok I just went out to the car and plugged it in. I can data log and clear and check engine codes BUT the option to modify my tune is not there. I tried to restore the stock tune and I am told none is stored. When I try to install a new one I am told a tune is already installed. HELP
- 06 300c ya
OK, I will change the subject to Can't Modify Tune. See mey original post above for more details. I have no option to Modify the tune.
marcchoquette
Mike I plugged my intune in to see if there was an update missing and I get a message to contact tech support with CALIBRATION ID FCCN5H6 STATUS ERROR. What is my next move?
please post your info.xml files.
Might help to start your own thread for each one of these issues, as they dont seem to be the same.
- 06 300c ya
Alright, I'll start my own post later on when I have access to the tuner. Thanks Mike!
marcchoquette
Here you go.
- info.xml
- (553 Bytes) Downloaded 210 times
is there a tune inthe tunes folder called diablotunedbackup.frg?marcchoquette wrote:Here you go.
if so, please post it here.
marcchoquette
I think this is what you are looking for.
- PCM_FCCN5H6_BackupDiabloTune.frg
- (428.39 KiB) Downloaded 292 times
