2011 JK RIPP SC Tune Update
ChuckMRN
Post by ChuckMRN »
I finished my SC install late Sunday and started to work on installing the tune today. I am not able to get the update file from RIPP installed on the tool. I drag the file to the root of the USB file and it starts to install, but then on the tool screen It says "installation of RIPP-DCX_TUNES-1trm01bd.ITF is not supported by this DiabloSport inTune." I then have to push "continue" and the tool boots. I have tried doing this with the original back-up file on the tool and with the tool released from the vehicle (no back-up on the tool). I checked the tool plugged into the vehicle both ways and the tunes do not show up. Any suggestions?
Re: 2011 JK RIPP SC Tune Update
please post the info.xml file from the intune drive.
I could have sworn the first step in the instructions is to install the tune first, so as to avoid having a vehicle with the blower on it that you cant drive if you run into tune related problems :)
ChuckMRN
Post by ChuckMRN »
- <tool_info>
<main full_version="InTune-1r03h 02/25/2013 05:23:14 PM" sw_rev="1r03h" svn="5947" />
<registration sn="CIJRO0C-1" status="1" />
<cal_id PCM="68057142AF" />
<restore id="0" vin="1J4BA6H14BL523572" bc="4" />
<system_db info="1r01b" dtc="1r01a" vin="1r01c" />
<db mfr="DCX" tune="1r01b" pid="1r01a" />
<db mfr="FORD" pid="1r01a" />
<db mfr="GM" pid="1r01a" />
<license avail="1" tuned="1" />
<updates count="4" />
<oem tool_oem="DIABLODCX" />
</tool_info>
thanks
thats a I-1000-DCX, not an RM-1000 model, you cant load the RIPP tune database.
You'll need to let it save the stock tune and email it to RIPP to have them make you a custom tune.
ChuckMRN
Post by ChuckMRN »
I have sent above info to RIPP. I will post the follow up/resolution.
Thank you
ChuckMRN
Post by ChuckMRN »
Got the correct tune info/file from RIPP today and it installed correctly. This tool works as advertised. I look forward to spending more time with it to check out all of the functions.
Thank you
glad to hear it :)
enjoy.
