Need help on "How to" Modify tune and 93 CAI Perf
Posted: Sun Nov 18, 2007 4:26 am
by Jected
Just need some clarification on the "Modify Tune" function please.
I am running the 93CAI Perf Tune and I wanted to modify some parameters within that tune. Is this done through "Modify Tune" function?
I went to do this today and it put my car back to stock and only saved the settings I changed.
Does using "MODIFY TUNE" function mean that you have put your original stock tune back into the PCM which will then be modified? Am I then needing to re load the "93 CAI Perf Tune" once the "Modify Tune" has installed. Will these changes then carry over to the "93 CAI Perf tune".
Or am I doing it completely wrong.
Example of what I am trying to do.
- Run the 93 CAI Perf Tune.
- I want to raise rev limit in Park and Neutral
- Add fuel and adjust timing slightly (to suit)
- Raise speed limiter.
Thanks in advance.
Daniel.
Posted: Sun Nov 18, 2007 2:44 pm
by alssiri
You should go to the 93 CAI Perf Tune then modify tune then modify parameters.
Ahmad
Posted: Sun Nov 18, 2007 8:22 pm
by Jected
Got it now. Thanks mate.
