2012 Durango R/T install? Key fob cycle or leave on?
hemibuck
Post by hemibuck »
So I received the DCX and did the latest update and went to go install the 87 tune and when it asked me to cycle the key I thought I needed to push the button over and over but it would just turn off the vehicle and not come back on. I pulled the tuner out wondering if I had just bricked the rig and it started up. I then read in the vehicle manual about how to use the key fob like a key to cycle back and forth for accessory and off so I tried once again and was successful in installing the tune by cycling the key fob.
But now I am reading that cycling the key fob is a bad thing to do? I guess we are supposed to leave the ignition on and hit the green button? Why are there no instructions for this if we risk bricking the car or ruining a key fob? What is the official way to install a tune on a Durango with push button start? Or any Dodge with a push button for that matter. Thanks for your help!
Re: 2012 Durango R/T install? Key fob cycle or leave on?
its a bug, the way around it is to leave the key on, and use the key, not the button :)
No bricking...
hemibuck
Post by hemibuck »
So use the key fob like a key and cycle back and forth? No key fob problems or bricking?
firefox7518
Post by firefox7518 »
As Mike said, just leave it in the one position and do not cycle it. Check the green and it goes on...
hemibuck
Post by hemibuck »
Ok thanks
