2012 Dodge Challenger 3.6 Intune Problem?
Tried tuning vehicle and says i need to update the software which i have already, what do i need to do?
Re: 2012 Dodge Challenger 3.6 Intune Problem?
the update was removed late yesterday to resolve an issue with different vehicles.
Post a copy of the info.xml file from the intune drive please.
how would i access that im using MAC
go to the intune drive and the file is there...
<tool_info>
<main full_version='InTune-1r03i 05/06/2013 01:43:25 PM' sw_rev='1r03i' svn='6219'/>
<registration sn='CIJML64-1' status='0'/>
<cal_id PCM='68078638AF' CM1='05150729AEkc3l0'/>
<restore id='0' vin='2C3CDYAG7CH206593' bc='0'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01c'/>
<db mfr='DCX' tune='1r01b' pid='1r01a'/>
<db mfr='FORD' pid='1r01a'/>
<db mfr='GM' pid='1r01a'/>
<license avail='1' tuned='0'/>
<unsupported calid='68078638AF' vin='2C3CDYAG7CH206593' oem='DCX'/>
<updates count='1'/>
<oem tool_oem='DIABLODCX'/>
</tool_info>
</tool_info>
email sent...
it is saying "PCM Calibration for 23CDYAG&CH206593 might need an update. Check for a Calibration Update?"
do as it asks
plug it into the pc, let the updater run, and it will download the cal update.
if not, attach a copy of the actual info file here please.
Firmware Info:
Application: 1r03i
DCX Tune Db: 1r01c(ok)
DCX PID Db: 1r01a(ok)
FORD PID Db: 1r01a(ok)
GM PID Db: 1r01a(ok)
DTC Db: 1r01a(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
Application: 1r03i
DTC Db: 1r01a(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
info
now its saying cant update till registered, how do i do so on mac
drag/drop the reg file to the intune drive, and let it reboot, that will register the tool.Oconer wrote:now its saying cant update till registered, how do i do so on mac
is it normal when i drag and drop the intune reboots then it loads back up but there is nothing in the intune drive
Glad I'm not the only one with this issue, hope it will be resolved soon
Same deal here man 450 hope it's all worth it once its up and going
