Gear Ratio?
Garza
Gear Ratio?
Post by Garza »
What's the difference between the three gear ratios you have in the tune setup? Is it better to use a higher ratio?
Re: Gear Ratio?
only adjust this if you changed the gears in your rear end.
indypace78
Re: Gear Ratio?
Post by indypace78 »
If I change my rear gears from 3.06 to 3.92 do I need to change anything else in the programmer or will shift points be changed automatically?
Re: Gear Ratio?
Just the axle ratio setting is all thats needed.
