fueling issue
Posted: Fri May 17, 2013 3:19 pm
by Rippin07
Having trouble with WOT fuel. Adjust the OL fuel table and no change what so ever, keeps running 10.2:1 AFR no matter what is commanded. Looked for help but seems no dealer section anymore??
Car is an 09 SRT8 Challenger with the Eforce SC and full exhaust.
Any ideas?? Even if I use the options to lean out the fuel nothing changes.
Re: fueling issue
Posted: Fri May 17, 2013 3:48 pm
by Mike_Levy
Theres a dealer section, I can see it. Mike just has to give you access to it.
Re: fueling issue
Posted: Fri May 17, 2013 4:19 pm
sounds like it is going into COT...try disabling it to confirm.
Re: fueling issue
Posted: Sun May 19, 2013 11:51 am
by Rippin07
COT is disabled, got it figured out, bad map sensor and scanner not showing right p/ratio. Changed map, scanner showed me where I really was in the map, all good.
Thanks for the tips.
