U7146 MAF & TPS Voltage Readings
Posted: Tue Mar 06, 2007 1:06 pm
When data logging the MAF and TPS sensor voltages are reported as "A/D Counts" and not voltage. The readings (at idle of 750 rpm) are approx. 168-169 for MAF Counts and 196-197 for TPS Counts. I am using a MAFia interface set to "2" correction between ECU and MAF sensor.
This appears to be the sample rate, or sampling sum the processor reads from the A/D in a given time interval, however I am looking for voltage on both counts. It appears the conversion is approximately divide by 205 or 206 to arrive at the actual voltage, but this is just a rough estimation on my part.
Can you provide me with the correct conversion factor?
Thanks!
Brian
Thanks!
Brian
