.csv export issue
wpelletier
.csv export issue
Post by wpelletier »
Hey guys. I'm trying to figure this one out.
I am trying to log with my i1000, open the log with Dataviewer and export to .csv format for use with Dslogredux. I can log just fine, Dataviewer reads the logs and plays them back just fine, but when I export to .csv, the file is screwed up. I have done this in the past successfully, but I can't seem to get my head around this this time. Any ideas?
I have attached both file formats to help. I don't really know if the logs from the Intune is to blame or Dataviewer, or how to fix it.
85003_00.csv
Export from Dataviewer
(2.19 MiB) Downloaded 555 times
85003_00.log
Intune Log
(1.44 MiB) Downloaded 460 times
Re: .csv export issue
yeah, there is a data logging issue for GM's with the intune right now...
they are aware of the issue and are working to fix the problem...
wpelletier
Ah, nuts!
Thanks for the quick reply!
GA_Dawg
Post by GA_Dawg »
Do you know if this has been resolved yet?
a fix has been tested and appears to be working fine, but it has not been released yet in an update, because there are other things being rolled into that next update as well, so they're waiting for everything to be done and ready to go before releasing the next update....
this will fix it for you....
InTune-1t03lc.itf
(1.6 MiB) Downloaded 484 times
GA_Dawg
Post by GA_Dawg »
Thanks guys. Ill give it a go and let you know if it works for me or not.
GA_Dawg
Post by GA_Dawg »
Its Working again. Thanks Alot!
Return to “DataViewer/DV2”
