2014 GT Question
jasinedward
2014 GT Question
Post by jasinedward »
Just traded up to a 2014 Mustang GT manual from a 2013 Mustang v6 auto. I unmarried my tuner from the v6 and tuned the GT with the 93 performance tune. When I went to look at the mods available for the tune I checked the gear ratio, it looked like it was set to 3.31. This car came from the factory with 3.73's according to the vin# and window sticker.
When I had it on the last car, it showed I had the 2.73's when I loaded the tune. So when I loaded it into the 2014 I did not change any settings and checked my speedo with a GPS app for my phone. It is still accurate. This doesn't mean the window sticker lied..... does it? It sure feels like a 3.73 gear set...
Also, what kind of hp/torque increases do you see on average with the Intune? This car is so damn fast, I just can't tell the difference on the street. I uploaded my info file and my last tune written for reference.
Thanks in advance!
PCM_FPFD2AA_LastTuneWritten.frg
(591.27 KiB) Downloaded 99 times
info.xml
(489 Bytes) Downloaded 104 times
Re: 2014 GT Question
if you didnt change the gears, dont change it in the tuner :)
it wont change it unless you do, the default value that it shows is not necessarily whats in your vehicle.
jasinedward
Thanks! I was pretty close to changing it too..... :shock: It even made me do a double take on my window sticker.... :D
sohfast94
Post by sohfast94 »
jasinedward wrote:Also, what kind of hp/torque increases do you see on average with the Intune? This car is so damn fast, I just can't tell the difference on the street. I uploaded my info file and my last tune written for reference.
Thanks in advance!
It depends, normally 18-25whp
I assume you have already setup the default logging on the intune from the V6 so get me a couple WOT logs and I'll take a look at it for you.
Insert Clever comment here...
jasinedward
Will do! Thanks!
jasinedward
That is the best I could do with the weather we have going on....
00438_00.log
(500.21 KiB) Downloaded 93 times
00438_01.log
(549.26 KiB) Downloaded 105 times
jasinedward
I did notice some knock retard..... I never had this with the v6..... is it normal?
sohfast94
Post by sohfast94 »
1.5 is nothing. It may just be the gas in the tank.
sohfast94
Post by sohfast94 »
Look 56 seconds on the graph in dataviewer. That's WOT. Notice the commanded lambda. It's better to just sample 1 or 2 gears of WOT so it's either for me to see what I'm looking at.
