Is there a secret?
Posted: Tue Jun 04, 2013 9:48 am
by Tweaked
Is there a secret to getting the Intune to consistently detect the ECU? 9/10 times I plug this thing into my car it can't find the ECU. I would like to datalog, but I don't have time to sit there for a half hour just trying to get this thing to connect.
P.S. Will the Intune datalog the stock tune? I ask because this means that the intune is unmarried.
Re: Is there a secret?
Posted: Tue Jun 04, 2013 9:56 am
sounds like you may have a cable/connectivity issue.
you can log any tune, stock or otherwise
Posted: Tue Jun 04, 2013 10:38 am
by Tweaked
mikel wrote:sounds like you may have a cable/connectivity issue.
I just got this back from RMA where they replaced the OBDII socket. What else could be wrong if it has a new socket?
Posted: Tue Jun 04, 2013 11:12 am
by Mike_Levy
I don't think its the inTune. If the socket was just replaced, and the cable is good, the problem has to be your car.
Posted: Tue Jun 04, 2013 11:16 am
got another vehicle you can try it in?
Posted: Tue Jun 04, 2013 11:20 am
by Tweaked
mikel wrote:got another vehicle you can try it in?
Only my wifes 2011 Avenger.
it should connect to that for logging or codes...
Posted: Tue Jun 04, 2013 11:24 am
by Tweaked
mikel wrote:it should connect to that for logging or codes...
Ok, I'll give that a try tonight. Could the problem be that I have a stage 1 computer instead of stock?
Posted: Tue Jun 04, 2013 11:34 am
not likely....
