2 questions
2 questions
I bought a diablo Dcx for my 2012 charger rt . I registered it now I got a code what do I do with that? Wheres the 93 tune is that the diablo tune? The options are the diablo tune 91 tune and modify the stock tune.
Re: 2 questions
Diablo Tune is the 93 octane tune.
Re: 2 questions
Thanks some gas stations only have 91 would this hurt the car if I used the 93 tune ? I also read you post a +5 rich increase with a cai what about setting the cooling fans at?
Re: 2 questions
Can't run 91 on the 93 tune. Hemis knock even if you use the right octane, using less will do damage. +5 is close for a CAI, but that depends on the intake. Some are no better than the stock box and don't need it. Fan temps depend on what T-stat you're using. Drop the temps by the same amount as the T-stat. Stock is 203°, so if you use a 180, drop everything 23°. If you use a 160, drop them by 43° (and expect it to throw a code)
Re: 2 questions
That explains why everyone sells the 180 thermostat ... I have the mopar cai the new one that actually pulls cool air and is sealed off under the hood..
