trinity 180 degree thermostat
Posted: Wed Jun 12, 2013 5:02 pm
by citiscene.productions
hi i have a 2012 jeep gc 5.7 is there a setting to put a 180* thermostat and not cause any codes ? i have the trinity and dont see a choice for thermostat only fans, also in the quick adjust or the 87 tune i dont see a tranny setting for firm / soft ? . so if i want to put a 180* in and not cause any codes or fail ny emission test what do i do? thanks in advance
Re: trinity 180 degree thermostat
Posted: Wed Jun 12, 2013 5:22 pm
by Mike_Levy
Drop all the fan temperatures by 23°.
Posted: Wed Jun 12, 2013 5:29 pm
thanks for the fast reply
so just lower fan temps? i wont get that not warming up code or a mil light? thanks
Posted: Wed Jun 12, 2013 7:01 pm
by Mike_Levy
Just lower the temps. Shouldn't get the code unless you're using a JET Thermostat. I ran the NAPA 180 on both my SRT8s with the fan temps lowered and it never threw a temperature code. The JET has a tendency to throw codes, but the NAPA and MotoRad seem to be more reliable.
Posted: Wed Jun 12, 2013 8:53 pm
any problems in winter ? north east gets cold
Posted: Wed Jun 12, 2013 10:38 pm
by Mike_Levy
I never had any problems. I'm in NYC, so I have the same weather as you.
Posted: Thu Jun 13, 2013 9:44 am
Thanks mike. I appreciate the response. I'm in Staten Island my self
I'm just going to order the stat you recommend . If there is a cel can diablo send me a modified tune to turn it off
Posted: Tue Jun 18, 2013 6:30 pm
by charlieboy111
If you drop the temp to turn the fan on too much wont it cause your fan to run constant?
Posted: Tue Jun 18, 2013 6:47 pm
by Mike_Levy
If you drop it too much, yes. Thats why we're dropping is 23°. Stock thermostat is 203, 180 is 23° lower.
Posted: Fri Sep 27, 2013 6:53 pm
by Restrepoj123
With that thermostat how hot does coolant go up to. Am running the jet 180 and changed settings on trinity for fans but don't think there working mine is going up to from 210-226
Posted: Fri Sep 27, 2013 7:17 pm
by Mike_Levy
Mine used to stay right around 180 unless I was in heavy traffic or really hot weather. That was in both SRT8s.
