My 5.7 vs her 3.6
MightyQwin
My 5.7 vs her 3.6
I currently have the 93 tune loaded on my 2012 5.7L Charger with 20% throttle and shift firmness adjusted. Yet my throttle response still cant hold a candle to my daughters oem throttle response on her 2011 3.6L Challenger.
Is there anything else I can adjust to get the kind of throttle response she has, other then buy a Challenger?
Re: My 5.7 vs her 3.6
I'm hoping someone with some knowledge of tuners responds to this post also. My wife has a 2010 Charger 3.5L and I have a 2011 3.6L. If we drag she will blow the doors off my charger with 20% throttle with a 91 octane tune until I get to about 3rd gear; then it's a wrap.
There are differences, if you want to try some more throttle boost on the 5.7, post up the last tune written.
MightyQwin
I'd be glad too, just coach me through what I'm posting up?mikel wrote:There are differences, if you want to try some more throttle boost on the 5.7, post up the last tune written.
MightyQwin
Here ya go
MightyQwin
Impatiently waiting here Mike
give this a shotMightyQwin wrote:Here ya go
MightyQwin
Thanks Mike, I'll report back and let ya know how it worked out
MightyQwin
Well I got to tell you Mike, I been in negotiations with my dealer to upgrade to a SRT, and now this tiny little file has made me consider pulling out of the deal. With the normal 93 tune with a 20% throttle boost setting, I'd still would get lull/hesitation, but this boost file, man she just rips around. I highly recommend you add that to the normal tunes. My throttle is now every bit as spunky as my kids Challenger.
Thank you so much.
Now if I could only learn how to switch tunes without a fail, I always have to go back to stock first or I get a fail.
Thank you so much.
glad to hear it.
We'll sort out the flash failures....
Dropdesigns
any chance of getting a 91 oct version of this tune?
pull 2* of spark at WOT for use with 91
Dropdesigns
Mike,
Please excuse my ignorance as this is my 2nd day with the DCX. When I take the file posted about and place it in my "tunes" folder it tells me its not for my vehicle and then it does not show up in the Intune when I plug it into the ODB? My car is a 2012 Challenger RT, I'm guessing this makes a difference.
you cant use someone elses tune....
