I bought my 03 silverado new and programmed it with a hypertech, set it back to stock and sold the hypertech. I recently bought a U7195 and like the performance it provides with a stock tune. I am planning on swapping the 4.8 out with a 6.0 engine. I am swapping the 3.42 rear gear to 4.10 and keeping the auto transmission stock.
What would you suggest in order to get the ECU setup to run the 6.0 engine?
Engine Swap 03 silverado 4.8 to 6.0 - U7195
ChrisDiabloSport
RE: Engine Swap 03 silverado 4.8 to 6.0 - U7195
You will basically just need to Purchase a Custom Tune so that your PCM will work with the new engine.
Thank You
Chris Johnson
1865 S.W. 4th Ave. Suite D2
Delray Beach Florida 33444
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
Chris Johnson
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
Re: RE: Engine Swap 03 silverado 4.8 to 6.0 - U7195
Assuming I burned the stock tune back into my truck, would my U7195 be able to tune the PCM in my truck if I were to get the dealership to put a stock tune in for a 6.0 engine? Dollarwise, the dealership is going to charge me about $100 an a custom tune will run $250...just makes sence to me. Also, is there software available to modify the predator tunes?ChrisDiabloSport wrote:You will basically just need to Purchase a Custom Tune so that your PCM will work with the new engine.
I have been researching this for a few days now...
I am looking to purchase a 6.0L engine and swap it into my 03 silverado. If i were to get the PCM that came with the 6.0L engine would I then be able to simply tune the new 6.0L and it's PCM with my existing predator? All this assuming that i reload the stock tune back into my 4.8 prior to the swap.
Yes you would, you would have to get a custom tune with vats turned off unless you bring it to the dealer for a vats relearn, vats is the vehicle anti theft system.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
If you send me a copy of your original backup file from the Predator, I can set you up with the proper tune for a 6.0.
You'll load it to the Predator as a custom tune, then put that tune in the truck.
No need to swap out the PCM.
