Hey bought a used intune and don't think i have all the files i need loaded on to it. I have plugged it in an it updated the first time (each time i have tried after it says up to date). I see some comments that i should have getcdrom.exe in the "CD" drive but i don't see it there.
Also, i have downloaded all the files listed in another thread (vin_1r01a, DTC_CODES-1r01a.ITF, DBNAMES-1r01b.ITF, GM_PID-1r01a.ITF, DCX_PID-1r01a.ITF, FORD_PID-1r01a.ITF) but haven't loaded them yet. Do i just drop these into the intune USB (or non CD drive part)? If so, on the main screen or into a specific folder?
Car is a '99 vette. Please help and thanks in advance!
Help starting up and loading tunes
- info.xml
- (638 Bytes) Downloaded 146 times
Re: Help starting up and loading tunes
everything looks good, if you need to update, load the files to the intune drive and the tool will import them.
Just to confirm, you mean drag and drop them in the order from above then all should be good? Thanks
you dont need any of those files....
