Car wont start!
daxgarnica
Car wont start!
I have a 2011 Dodge Challenger SE V6. So a got a new DiabloSport T1000. Great, but something went wrong. I downloaded all the updates. I started the reprograming. You start with the car on but not running. It starts reprograming, Its all plug and play. It will ask you to turn the car off, more programing and then it will ask you to turn on the ignition. This is where I'm stuck. The car wont turn on. What to do? I check the fuse to the ignition, its good. I had someone jump me, not the problem. Help me please.
Re: Car wont start!
Are you using the key or the button? If its the button, pull it out and use the key.
daxgarnica
Re: Car wont start!
I can pull out the button? how do I do that?
daxgarnica
Re: Car wont start!
Okay, I was able to put out the button and start it and finish loading the software. The problem I have now is the T1000 wont tune my car because it says that the original tune was not there. I think it was deleted during the first attempt. What do I do now? Is there away to reload the original tuning?
Re: Car wont start!
It will read the stock tune out when you go to reload the new tune.
daxgarnica
Re: Car wont start!
Thank you, it loaded after a few trys.
