adjust downshift behavior?
Posted: Sun Jul 21, 2013 9:37 pm
by elmer
I'm struggling with getting my downshifting to function how I'd like.
I've got an 03 Avalanche, so my predator is a U7193. The only parameter I have that should affect this is called "Downshift MPH." I had the 3->2 Tow/Haul value set to 62.98MPH. I also tried values greater than, and less than that. Regardless of what I do, if I am cruising along at 65mph, I have to let it slow to 54mph before the transmission will drop a gear. I'm adjusting the tow/haul value as I often tap the Tow/Haul button before climbing a hill to help maintain speed. If I get this figured out I may adjust the Normal parameters so I don't feel like I need to tap the Tow/Haul button to negotiate hills.
Does anyone have any pointers? I'm wondering if I'm not headed toward a custom tune to help out with this... Or an intune...
Re: adjust downshift behavior?
Posted: Mon Jul 22, 2013 12:06 am
by 06MonteSS
shift points usually have to hit both a MPH AND an RPM value before it will allow the shift....
so lower the shift point RPM as well...
Posted: Fri Jul 26, 2013 10:11 am
by elmer
Thanks Lew,
You probably noticed this nearly identical post on the avalanche forum. You sufficiently answered my questions there. Now the burden is on me to decide if this annoyance is worth the cost of a custom tune or not. If I added electric fans or something else that also required a custom tune I could maybe justify it. Otherwise I'm pretty happy with how things are going, aside from the upshifts. Been getting 18mpg on a couple tanks, 16mpg when I run the A/C all the time. Dialing in the LTFT's made a big difference there.
