Had a Predator and sold it after unmarrying it. Upgraded to a Trinity and when I attempt to put the tune on I get;
"TRINITY DCX_GAS DOES NOT SUPPORT CALID:0469239AK TOOL UPDATE MIGHT BE AVAILABLE"
I bought it used and it is supposed to have the current version. It is showing VER: v.1r09i.
Not sure about the other info, but if it helps it also shows;
PCM: 05030232AF
TCM: 0469239AK
Any help would be appreciated as I loved the canned tune it had and I can't live with stock anymore!
06 300 SRT8 - CALID problem
Re: 06 300 SRT8 - CALID problem
change vehicle type to 2010 charger then try again
Tried it but got the same message
try switching back to 2006.
did that and still no dice!
weird. try picking 05.
Okay, being a quick study, I saw where this was going so I tried a few more variants and the 2008 300 SRT8 worked…Im good to go! Thanks
Dang, spoke too soon. The tune is installed, but when I do the monitoring it has two options for 2007 and up. As a result, when I select it the only thing it will monitor is MAP.
Help!
Help!
switch back to 05-06 for monitoring, it will work fine96IMPSS wrote:Dang, spoke too soon. The tune is installed, but when I do the monitoring it has two options for 2007 and up. As a result, when I select it the only thing it will monitor is MAP.
Help!
