Tire pressure threshold and throttle boost problem!
fanthermic
Post by fanthermic »
Sorry it seems nobody is replying in the INTUNE I-1000 DCX forum, I had to ask the same question again here, as it is basically same in terms of tuning.
First problem is my throttle booster doesn't seem to be working I tried both + and - 20%...cant feel any difference.
Also, I tried to tune my 2012 wrangler 3.6 pentastar automatic with intune I-1000 dcx, the tune itself seems to be fine, and according to my GPS and speedo it seems the tire size and gear ratio calibration is working as it should (I have larger tire and lower gear ratio installed). However no matter how low I set the tire pressure threshold to my jeep just keep reporting the low tire pressure warning. Any ideas?
my info.xml and last tune written is attached. Please do help.
Also, if for some reason, say maintenances, the battery got disconnected. Does the tune stay in? Or I have to reprogram the ecu? And the what about gear ratio, tire size, throttle booster, tire pressure, fan speed, WOT FUEL, WOT SPARK, etc do I have to re-set all these after a battery disconnection?
Anyone? Please help!
info.xml
(489 Bytes) Downloaded 129 times
PCM_68070364AG_LastTuneWritten.drg
(79.12 KiB) Downloaded 127 times
