LT KNK seems to be at shift points
kies277
Post by kies277 »
I did some data logging and had taken off 1 degree of timing and added 5% fuel across the board. I attached my old and new logs, my LT KNK is down to 1.0 and seems to be mostly around the shift points and 4200 or so RPM. What do you guys think?
I have a wideband O2, but it is inop right now. My email just informed me that the new wire was just delivered so I can get it working when I get home and run some logs with the actual AFR.
2006 Dodge Charger R/T (with a 6.1L engine replacement)
Spartan Max cam
Ported throttle body
Underdrive Pulley
Torque converter
CAI
Flowmaster catback
20130807.log
(376.1 KiB) Downloaded 210 times
20130806.log
(336.32 KiB) Downloaded 208 times
Spartan Max cam
Underdrive Pulley
Torque converter
CAI
Flowmaster catback
Re: LT KNK seems to be at shift points
All good, a quick blip of kr at the shift is totally normal.
kies277
Post by kies277 »
Even LT knk? I thought only the ST knk should spike a little on the shift?
Spartan Max cam
Underdrive Pulley
Torque converter
CAI
Flowmaster catback
kies277
Post by kies277 »
...and when the LT goes up to 1.0, it seems to hang there for the duration
Spartan Max cam
Underdrive Pulley
Torque converter
CAI
Flowmaster catback
add a little fuel up top....
kies277
Post by kies277 »
Will do, thanks a bunch.
Spartan Max cam
Underdrive Pulley
Torque converter
CAI
Flowmaster catback
