2003 Mustang GT....tune fails at 99%
- electricmarquis
I bought a Trinity so Im trying to hook my buddy at work up with my intune. When tuning it records stock file but when writing performace tune it fails at 99% every time. Im not a Ford guy.
2010 Challenger SRT8
Re: 2003 Mustang GT....tune fails at 99%
hmm, could there be a chip on the pcm?
that would be my first guess here.
the pcm is in the pass. side kick panel, held in by *I think* a 10mm bolt, take the bolt out, pull the pcm down, and if there is a chip, its generally sticking out the side of the pcm on the exposed j-port.
If its there, make sure the keys are out of the ignition, and pull the battery, then remove the chip, and then redo the tune
- electricmarquis
I will check with him tomorrow. He did buy the GT used from a local guy. Still 38k miles young.
yeah, its not uncommon to see lots of them with chips in there that nobody knew anything about
- electricmarquis
No Chip was installed. He got the lower of the two tunes to install. The Diablo 93 one failed.
so the diablo tune fails anytime he tries it?
- electricmarquis
The Diablo tune went in today. I have no clue. Nothing was done any different. Good battery voltage etc.
hmmm....id check any/all connectors at the OBDII port first.
